farookb Posted August 11, 2014 Report Share Posted August 11, 2014 hey peeps. We all know that somehwere the global warmimg is increasing because of the emissions of gases from the car. Please suggest if there is any possibility to reduce the emission of carbon dioxide from the car? Link to comment Share on other sites More sharing options...
travis Posted August 12, 2014 Report Share Posted August 12, 2014 Well, there is lot of ways we can adopt to reduce the emission of CO2 from our car. I can completely understand that it’s impossible to leave your car and start driving a bicycle, that too in UAE. It’s not even an option. But yes, if we just follow some tips, we can definitely reduce the greenhouse gasses emission. Shut your engine down: Well it’s not wrong to say that the Dubai traffic is horrible! So when you are stuck in the traffic, or waiting for your friend in the car, or even just asking an address to a person, shut your car engine. That can almost reduce 5% of emission of greenhouse gases. I know it’s not a big amount, but if everyone of us starts doing that, it will be a huge percent. Have a moderate driving: When you start driving moderately without rushing to reach somewhere that also helps in reducing the emission of CO2 from the car. This will help in reducing the emission by 15%. Searching for Parking: I have seen so many people just roaming around the parking area, to get the best parking place. I mean even if the nearest parking is free, they don’t want to opt for it. So one way to reduce global warming is to stop wasting your time to look for a perfect parking and try to do parallel parking wherever found. Bleeding the brakes: If one bleeds the brake too much, the emission of harmful gases is really common. So try not to bleed brakes unnecessary. If there is any mechanical issue, then give it a try otherwise NO! This can help in reducing the emission of harmful gases by 20%. Try walking if applicable: Try to avoid driving car when you just have to go two blocks away. It’s healthy for the driver as well as healthy for environment. Link to comment Share on other sites More sharing options...
ronaldeve Posted August 17, 2014 Report Share Posted August 17, 2014 Thanks Travis for sharing. I must say, really informative! And its really important to actually work upon such things. trust me, its gonna affect the global warming in a good way. Link to comment Share on other sites More sharing options...
ihabb Posted May 15, 2015 Report Share Posted May 15, 2015 You've got some good points there travis. If I may add, you can use an eco-friendly car model that works on some alternative power like electric cars or using biofuel. Link to comment Share on other sites More sharing options...
erfankr Posted May 16, 2015 Report Share Posted May 16, 2015 What many people who own cars with manual transmission forget is to change gears. You should always change gears and use the right one in order to reduce gas emissions and to protect your engine too. Link to comment Share on other sites More sharing options...
