Tires Dimension
Its simple! Its mentioed o your car. There is a sequence of no.s mentioned on your car. \
For example: P225/70R16 91S
here P is the initial by the tire compay. 225 is the width of the tire, 70 is the aspect ratio, R stands for radial construction, 16 is for the RIM diameter, 91 is the load index and the last letter S symbolize the spped ratio of the tyre.
