zulfi Posted August 19, 2014 Report Share Posted August 19, 2014 What are the general problems in fuel system of the car? Link to comment Share on other sites More sharing options...
anoop Posted August 20, 2014 Report Share Posted August 20, 2014 Fuel System is like a heart to the car engine. The fuel system basically delivers the fuel in the complete car system to function. The fuel system is crucial and that’s why need proper attention. Sometimes rash driving also causes issues with the fuel system. I know some common problems that one faces in the car because of the fuel system. Engine Sputtering: When engine suddenly starts sputtering at high speed that is because of issue in the fuel pump. Fatigue fuel pump is the cause of it. When there is loss of pressure in the fuel pump, the engine starts to sputter. Lost power when accelerating: Fuel pump needs to maintain an amount of pressure to deliver the fuel when accelerating the car. Sometimes the fuel pump is unable to do that. When it regains the pressure, it speeds up with acceleration. Engine surging: This is also very common when the fuel system doesn’t work properly. Engine doesn’t start: When the fuel pump is completely malfunctioned, the fuel does not reach the engine to start it. In all these problems, the fuel system either needs to be fixed properly or need to be replaced depends on the level of malfunction. But yes, ignoring the fuel system issues is foolishness. So if you think you are facing any of these troubles, then may be your fuel system needs attention. Sometimes just understanding what fuel pump does avoid lot of problems. To avoid any severe issue with the fuel pump, it’s always recommended to give your car for regular servicing. In regular servicing, the fuel pump is properly scanned and diagnosed for any issue persisting or any near future possibility to get any issue. That’s why we say; handle your car with care. It’s a machine not magic! Link to comment Share on other sites More sharing options...
lonely Posted August 21, 2014 Report Share Posted August 21, 2014 Good to discussed that. I was facing one such problem as well. There was power loss when i was trying to accelerate. o at least i know its becauseof the fuel pump. Thanks Man! Link to comment Share on other sites More sharing options...
tenace Posted April 27, 2015 Report Share Posted April 27, 2015 Thanks for sharing this useful information anoop. Many people forget about this system and they must face some severe consequences because of that. Some of the damage that can occur in this part of the vehicle cannot be repaired. Link to comment Share on other sites More sharing options...
