bassim Posted October 14, 2014 Report Share Posted October 14, 2014 How to differentiate whether the car battery is good or bad? Link to comment Share on other sites More sharing options...
ghassanali Posted November 3, 2014 Report Share Posted November 3, 2014 Sometimes you can just judge the battery by only looking at it. If you see any broken terminal, it means the car battery is going bad. Some things like bumping battery case, loose terminals of the battery or a short circuit are cases of bad battery. Otherwise you can check the battery using the voltemeter test. Connect the voltmeter with the terminals of your car battery and check the reading. If the voltage comes less than 11.0 V, then there is a chance that your battery had a short circuit. Link to comment Share on other sites More sharing options...
ihabb Posted May 20, 2015 Report Share Posted May 20, 2015 if you have problems when you are starting your car this may be a sign that you will soon have to replace your battery with a new one. You can also visit the nearest garage and they will measure the power in your battery. Link to comment Share on other sites More sharing options...
