lethalsamurai Posted November 7, 2014 Report Share Posted November 7, 2014 Hey Guys. I have Audi A3 from 3 years now. I want to change the starter in my car. Can i change it on my own? Link to comment Share on other sites More sharing options...
edward Posted November 7, 2014 Report Share Posted November 7, 2014 It is highly recommended that you get it changed from the workshop itself. If you have good knowledge about the dimensions and categories of starter, only then go for a DIY process. Link to comment Share on other sites More sharing options...
lethalsamurai Posted December 12, 2014 Author Report Share Posted December 12, 2014 Well I do have the good knowledge of the dimension of the starter, but not really sure how to change it. Can someone help me? Link to comment Share on other sites More sharing options...
fardin Posted December 12, 2014 Report Share Posted December 12, 2014 Ok. To change the starter follow the points: Before removing the starter, disconnect the negative terminal of the battery cable first and then the positive cable from the starter. Now use the ratchet to remove all the bolts which is holding the starter to the block. Now disconnect the starter and and install the new one by tightening the bolts by hand first and then use the ratchet to tighten it completely. At the end you can reconnect the battery cable back to the starter. Its done! Link to comment Share on other sites More sharing options...
Mach3 Posted May 28, 2015 Report Share Posted May 28, 2015 I would advise visiting a garage. There are many garages in UAE that can help you with this task and they don't charge much. The starter is a part of the car that is really complex although it's small. Link to comment Share on other sites More sharing options...
