why good battery in cold weather?
Basically in cold weather, the cranking load on the battery is much more compared to the summers. Because the weather is cols, the oil in the engine gets thicker and thus the cranking time goes high. If in that case, the battery of your car is low or let’s say the voltage is less than 12.45v, your battery needs urgent attention. If you ignore your battery then it will surely ditch you on the middle of the road.
