sailor Posted May 26, 2011 Report Share Posted May 26, 2011 the engine light, ABS light and traction control light is on with the exhaust throwing out white smoke in my 2006 Allroad Quattro. what am i looking at here Link to comment Share on other sites More sharing options...
audiawd Posted May 28, 2011 Report Share Posted May 28, 2011 White smoke caused by engine head gasket leak allowing coolant to be mix with engine oil and due to same your check engine light is on. Traction control may be because of same issue or may not be, im not sure. You must also be experiencing loss of power from mild to severe grade thats a key indicator of head gasket leak. If your coolant level is low and engine oil turned milky substance then its for sure you have head gasket leak there. Its a serious job as you have to open the engine head so seek a qualified technician only. Link to comment Share on other sites More sharing options...
imran Posted March 4, 2013 Report Share Posted March 4, 2013 What i have is not exactly the same problem but i have Low Brake Fluid which comes when i start the car only. what should this be? Link to comment Share on other sites More sharing options...
sailor Posted March 4, 2013 Author Report Share Posted March 4, 2013 There can be a leak that you can get it checked at a good workshop. Link to comment Share on other sites More sharing options...
