ajdin_A6 Posted February 17, 2015 Report Share Posted February 17, 2015 Greetings everyone, i had noticed small oil leak from this component nothing serous just a little i believe some oil pressure sensor or temperature sensor. Can anyone tell me exact name of it so i can find part nr and replace it. Thanks Link to comment Share on other sites More sharing options...
bean Posted March 18, 2015 Report Share Posted March 18, 2015 It's called oil pressure sensor sender. However I am not sure if its same from the image as it's not very clear. Link to comment Share on other sites More sharing options...
ethan Posted March 26, 2015 Report Share Posted March 26, 2015 This leak could be due to old and worn out washer, just a quick diy solution to change 2 dirham washer. Link to comment Share on other sites More sharing options...
ajdin_A6 Posted March 26, 2015 Author Report Share Posted March 26, 2015 Ty guys i did found and fix issue... Its called control valve solenoid Audi Part Number: 06E 109 257 F price in uae aroud 650 aed ... Well when i remove it there was one o-ring... I replaced that oring with closest one i could find ... And guess what no leak anymore btw same thing happend on other side on hall effect sensor also just replaced oring and no oil leak... Dunno is this happening due to fact its 2006 and am runing it on 160k kms ... Did not found on auto data anything related to this stuff ... Anyway it was great saving Link to comment Share on other sites More sharing options...
ethan Posted March 26, 2015 Report Share Posted March 26, 2015 Yup the right word is O-ring for that, washer is basically metal ones. Glad you fix it by yourself and save some bucks. cheers. 1 Link to comment Share on other sites More sharing options...
ajdin_A6 Posted March 26, 2015 Author Report Share Posted March 26, 2015 Cheers m8 and all the best to you and all of audi enthusiastic people Link to comment Share on other sites More sharing options...
