Aamil
2010 Mazda 3 - Clutch Failure Problem
I bought used 2010 model Mazda 3 last year in Jan, exactly one year back. Car was in great condition and it was fun to drive a manual gear. I liked everything up until it started throwing the never ending clutch change issue.
Last month my brother drove for a while and since then clutch was slipping on every gearshift with tranny slipping and shuddering. I changed the clutch for 1200 AED and picked up a car in bit rush without checking it thoroughly. To my surprise, after few days of driving again same problem occur. I showed the car to same mechanic and he blames my driving.
I showed to another mechanic he blamed that Mazda uses Ford parts in that model and hence that is not very good long lasting parts and that's why it failed on me and advice me to change the car to newer model in which mazda used their own parts and not Ford.
Im really clueless on which person to trust and what to do next, appreciate any advice from other Mazda 3 owners here. Thanks in advance.
The problem is not the fact that there are Ford parts in your Mazda, but rather that the mechanics did a poor job when they replaced the clutch.
There are no "Ford", or "Mazda" parts. Clutch manufacturers make clutches that are used in many different vehicles, Ford and Mazda included, but without knowing what brand of clutch was fitted, it is difficult to say for certain what the problem is in this case.
However, there are several possible reasons why the clutch is slipping now:
1.) The mechanics did not resurface the flywheel. When a clutch slips, the flywheel overheats, which causes the surface to become glazed. Glazed flywheel surfaces are too smooth for the clutch friction linings too "grip" the flywheel, hence the slippage.
2.) The mechanics did not replace the pressure plate. The spring tension in a pressure plate diminishes over time, so when only the clutch plate is replaced, the pressure plate is not strong enough to prevent the new clutch plate from slipping on the flywheel, and especially if the flywheel was not resurfaced.
3.) There may be oil on the new clutch. It often happens that when the crankshaft mainbearing oil seal leaks, oil eventually works its way onto the clutch, causing slippage. It also often happens that mechanics are too lazy to fix the oil leak, so even if they replaced the clutch as a complete kit, it will start slipping as soon as oil comes into contact with it.
4.) The mechanics damaged the clutch when they fitted the transmission. It often happens that the transmission is shaken around very violently by inexperienced mechanics when they refit the transmission. When this happens, the springs that control backlash in the clutch plate can be damaged, which can cause the new clutch to start slipping after a few days.
5.)The mechanics fitted a poor quality clutch. There are many clutch brands on the market that are extremely low quality, and it often happens that mechanics fit these clutches to increase their profits. The life times of some of these poor quality clutches can be measured in minutes, so it is very likely that you have one of these clutches in your car now.
6.) The mechanics fitted a rebuilt clutch, with the same results as point #5.
These are the most common causes of premature clutch failures, regardless of the make or brand of car. All clutches work in the same way, and if I were you, I would go back to the garage that replaced the clutch, and insist that they fix the problem.
All reputable clutches are also have warranties, irresepective of where in the world they are fitted, so insist on the problem being fixed under warranty conditions.
Hi Aamil
I do agree with Gautam but I would like to add one thing.
- mostly your car problem is not in the clutch plate I think it's on the pedal witch is mostly works in oil pressure that the cylinder failed and require replacement so its not going back to end and leave the plate touching the flywheel to over heat and wear.
some times you can find overall kit (after market) but it doesn't last for long time so replace with new and check the lower cylinder that push the plate as it doesn't have a spring to pull it back and replace the oil with the same grade (DOT3 or DOT4).
it's nice to have a manual car enjoy it!
Good Luck!
  • Similar Content
    • By Recall
      ANNOUNCEMENT
      Recall campaign Statement Takata passenger side front airbag inflator on Mazda6 GH & Mazda CX9
      In coordination with the UAE Ministry of Economy - Department of Consumer Protection, and in line with the directives of the Ministry of Economy, Galadari Automobile Co LTD LLC announces a recall Campaign for the Mazda 6 GH & Mazda CX9, model which will begin effective immediately.
      United Arab Emirates, Dubai, 10th Dec, 2016: Galadari Automobiles Co Ltd LLC, exclusive distributor of Mazda in the UAE, released the following statement
      Following communication with Mazda Motor Corporation, we have started a Recall Campaign affecting in the UAE.
      Due to continued exposure to high levels of absolute humidity may cause the front airbag
      inflator housing to rupture deploy Abnormally in the event of crash necessitating deployment of frontal air bag. An inflator rupture could result in metal fragments striking and potentially seriously injuring vehide occupants.
      For further darification, customers may contact the Galadari Automobiles Customer Care Centre on 800MAZDA (800-62932) from 8.00am - 5.00pm, Sunday to Thursday.
      We regret any inconvenience this may cause and thank our customers for their patience and understanding.
      Ministry of Economy Hotline No: 600 522 225
    • By Ali mardon
      Dear car lovers,
      I would love to receive your opinion regarding below.
      Recently, my ex-collegue told me that He wants to sell his Mazda6 2.0 2015 model. Mid option. Car is clean, no accident, no big issues. Almost perfect condition.He just recently changed the gear oil only
      car has done 75.000 km
      I know the market price. So, I felt that 40k aed can close the deal.
      however. I need to know If Mazda brand especially, Mazda 6 is reliable or not in a long term?( about maintenance, quality, parts service....etc)
      coz, I need to buy a car and drive it minimum 3-4 years
      Thanks in advance
    • By Hassam Tariq
      Since I got this car I am always struggling with the positioning of the HUD,
      I used to change the height in the settings to match me sitting position,
      but everytime I restart the car the display goes somewhere no one knows, so it required almost 80% of the time refixing whenever i sit in the car,
      So what i did is another way around, I reset all the settings to default and change me seating position according to the HUD,
      So the issue of repositioning it again and again is fixed(i assume everytime it was going to it start position or something)
      But now what happens is whenever I hit a bump or something the whole thing moves, I believe it's the projector inside. and it remains the same until i restart the car,
      Its a bit upward or downwards,
      Is this something happened to other MZ3 owners or should I just tell the dealer to replace or something?
      It's kind of frustrating .
    • By Marjoe
      We thank & salute all of our customers and suppliers for their valuable patronage during these years and offer our best service at all times.
      - Entertain Genuine / OEM and replacement parts.
      - We specialize in re-export of full range of Auto spare parts to all over the world in a professional way.
      - Professional intenders of auto spare parts
      - Export co-ordination through the Global network.
      - Indefinite identification through definite source out and pricing.
      - Most important element for us is the customer.
      - Prompt Delivery
      - Documentation includes pre-inspection through the Governmental agencies.
      We have professional, knowledgeable and competent staff, who provide prompt and hassle free services at all times. WE STRIVE TO GIVE THE BEST SERVICE.
      GENUINE PARTS FOR TOYOTA, NISSAN, DAIHATSU, SUBARU, MITSUBISHI, MAZDA, ISUZU, KIA, HYUNDAI, DAEWOO,HINO, LAND ROVER, RANGE ROVER, YAMAHA, MERCEDES BENZ AND BMW VEHICLES.
      Replacement and OEM Spare parts for Toyota, Nissan, Mitsubishi, Mazda, Subaru, Daihatsu, Isuzu, Kia, Hyundai, Daewoo, Mercedes Benz, GMC, Ford, Land Rover, Range Rover, Jeep and BMW vehicles.
      Besides, we can also provide you European auto spare parts in premium brands such as: Mann, Knecht, TRW, Bosch, Valeo, Hepu, SKF, Contitech, LUK, Aisin, SNR, Ruville, Denso, etc.
    • By Marjoe
      This is to introduce to you our esteemed organization “PAPYRUS AUTO SPARE PARTS” as an outstanding performer in the field of auto spare parts.
      With more than 20 years of experience in commercial vehicle spare parts trading especially Japanese and European cars, exporting parts to most of the African and Russian continent, now we are planning to expand the web with specialization in Toyota, Nissan, Mitsubishi, Isuzu, Hyundai, Daewoo, Kia, Mazda, Subaru, Komatsu, Caterpillar and Scania parts.
      We are equipped with computerized catalogues for most of the vehicle manufacturers, we are able to help you in finding the right parts, network with most of the genuine car spare supplier in Dubai we can help you in getting the price quoted online with in the swift time to enable you to verify the price with other suppliers and confirm your valuable quotation with us instantly.
      Having well experienced sales staff and most modern communication equipment, we are sure we can able to handle all your needs in spare parts and looking forward to your valuable co-operation.
