Majid Rana
Engine M119 S500 1998 engine die at 1500-2000 RPM when cold
14 posts in this topic
Im Having Mercedes S500 1998 W140 Engine 119
When i start my car after 7-8 hours engine starts fine no missing no stalling but when i put in gear and start acceleration as the RPM reaches 1500-2000 the engine starts missing and stalling and if i dont remove my feet from pedal the engine would DIE / OFF due to which i have to start it again and this missing/ stalling is only when RPM crosses 1500-2000 other wise in idle situation engine is smooth and  after 15-20 minutes of driving in that slow RPM engine automatically get fine and it starts accelerating well.my car is in  that situation since 5-6 months
Dear Majid ,
when was your last service done ? and what was actually done at that service?
do you have a record of regular service details?
with kind regards
I suspect few things to doubt that you might not be using correct grade of engine oil as suggested by Mercedes. It's also worth double checking the spark plug specifications and you might not be using colder plug that take sometime to warm and become normal thereafter.
Have you scanned the car with STAR software? What was the results and codes logged?
what kind of service are you asking for Mr.AK
Mr.Robert im using regular spark plugs made by mercedes
Mr.Barry i have not yet scanned car to see result of codes
I meant what was the regular service were fuel filter etc and plugs changed on time or not. These details might give a little clue about situation.
I have a bluetooth scanner if you want we can check your codes as well.
Kind regards
yes i changed fuel filter , spark plugs , air filter, fuel pump in march 2016 and my car had made a run of 20000 - 25000 kilometer only
Mr.AK where u live ? yes i would like to have scan for my car to diagnose this problem
On 04/12/2016 at 3:56 PM, Rahimdad said:
Congrats AK, nice friend, lucky you. Might just want to be friends with your friends, I want such gifts too.
I live in dubai al nahda 1 . If u r free tomorow evening we can check it. Regards
51 minutes ago, Ak said:
will it be free or what will be the charges for that????
Ak likes this
    • Engine Oil leaking from bottom.
    • Got my license
      Got my license
    • Newbie/Fewbie drive with Suhoor - 22 June
    • Battery charger
      Battery charger
    • Richard Hammond involved in another serious crash
    • Area 53 to Iftar Bowl - Night Drive - 15 June 2017
    • New job
      New job
    • Prado Cabin Noise
      Prado Cabin Noise
    • Coolent Leak
      Coolent Leak
    • Adjustable electronic window tints
    • Great Grand Iftar Drive - 9 June 2017
    • Ford pothole jumping suspension
    • Suhoor night drive - 1 June 2017
    • Viking rope and soft shackles
