Cruise control skipping the beat
In my Escalade, on long drive when i go at times i see cruise control stops working. I need to engage two to three times to make sure that it works and stay set at 115 km. Its an intermittent issue, so don't know where to start from as i mentioned same in last service to dealer and they said we will check and fix, but nothing has changed looks like they cant catch the real bug.
I thank you guys, if someone can please give some Einstein idea to explore this problem root cause.
You can start with swapping the cruise control relay with any other relay and see. As many times these minor issues caused by improper electrical voltage and if it gets fixed you can buy new relay. Also check the fuses as well.
If not you, i am sorry my friend you have to see qualified electrican. Good luck.
