The 3k, 5k, 10k oil change scam
After 15 years of working on vehicles in one form or another from road cars to racing cars to trucks and heavy plant equipment it's fair to say I have done a lot of oil changes. I wouldn't even like to guess at how many I've done, how many times I've spilt oil around my feet, how many times it has run down my sleeve.
I can do rough work, I can patch vehicles up to get them moving but generally, my work is completely professional and I like to do things properly. If I know I did a bad job during the day I would have trouble sleeping at night. I'm a professional  automotive technician. This is what I do, it's my passion and my life's work.
Coming from working in various places in Europe, I have only ever serviced vehicles to the manufacturers specification. I have always used the correct oil and I have always advised my customers when to come back for their next service according to what the manufacturer has specified. This is all I know, it is what I was trained to do.
It came as a big shock to my system when I first came to UAE and started working in Sharjah and discovered the whole 3k, 5k, 10k oil change bullshit that is going on. I haven't heard of a car built since the 1960s where the manufacturer specified that the oil had to be changed every 3k. Even then, they had recommended grades, not just whichever barrel is closest like what happens here.
I have recently tried to educate myself on this topic and have found out that it happens in parts of America too.
Bullshit, bullshit, bullshit. I'm sorry but that's the only word I can find to describe it.
This is all a ploy that has been concocted by service centres to sell their shitty, low quality oil and Chinese aftermarket oil filters in high quantities and make huge profits at the expense of you. These guys don't care about you, they don't care about your car or it's engine. They just want to make money.
Changing your oil every 3k, 5k or 10k means absolutely nothing when they're putting in the wrong oil and your engine will get sludged up anyway. Check out these videos I took of an engine I recently opened. The engine had only 70k on it, was serviced religiously every 10k but they put shitty, cheap, nasty oil in it.
Its seriously about time the public started standing up to these people and said no, you're full of shit and you just want to empty my wallet.
Educate yourselves. Read your cars handbook. Join marque specific car forums. Learn as much about what properly servicing your car actually entails. Don't fall for this bullshit and succumb to the scam. Tell your friends, tell your family. Letting service centres put any random oil into your car is damaging your engine. Know what oil should go into your car and know how often it should be changed.
Some manufacturers now recommend 18-24k oil changes. This is absolutely fine as long as you are using the oil that they recommend you use. If the recommended oil is 30-40 dhs more expensive then so what? What can you even buy for 40 dhs nowadays? It's cheaper than paying someone like me 5000 dhs to rebuild your engine after the cams, main bearings and crankshaft fail because one of the roadside service stations used whatever oil they happened to be making commission on at the time.
TL:DR The whole 3k, 5k, 10k oil change is a scam. Know how often your oil should be changed and know which oil should be used.
You definitely have a point there, but if you really think it is a scam then how come government companies like enoc, eppco, emarat and adnoc selling same interval oil? may be this car you got has been dealt with bad workshop and you are thinking it otherwise.
@taqir because they want your money. Pure and simple. When I joined my current garage, a lady from one of the above mentioned companies visited me and asked why would anyone use oil from one of the other above mentioned companies because it was crap.
The oil in the car came from one of the local oil companies. I won't name it but it was a blue jar with orange logo.
Engine sludge isn't a thing where I come from, it just doesn't happen. I have never seen it until I came here. People look after their cars according to manufacturers specification.
I am 100% confident in what I say and am happy to stand by it. Service centre intervals mean nothing. It's made up bullshit. Use whatever oil your vehicle manufacturer recommends and change it when they recommend.
I'd also like to add, if it isn't a scam, how come there isn't 3k, 5k, 10k changes all around the world? Why does it only happen in UAE and parts of America? Why does the rest of the world stick to manufacturer recommended service schedules?
Not to say I disagree with everything you've said. I'll say I wont agree to everything you've said either. Once again as in most your post, you bring in your European sensibilities into the middle east. You being a professional should know first hand what is oils biggest enemy, heat. In a climate where its close to 50C for better part of the year, I don't think any oil will last close to 25k kms in this heat. As you know one of the reason why sludge forms is when oil gets over cooked
Maybe in Europe and colder climates like up in N.Amerca and Canada where the temp hardly crosses 30C even in the hottest of summers and that also for a few days in year, you can have such huge intervals. As you you're self said consult your manufacturer and most manufacturers list such temps and dusty climate as extreme duty usage, sometimes cutting the oil interval changes in half. I remember reading this very thing in a VW owners manual
I do agree that also consult you manual as to what grade of oil. I personally have seen people not put in cheap oil but expensive or good oil but of the wrong grade and mostly because thats what the official parts seller sold them as and many a times the dealer himself. And I think that is the biggest blunder that happens here. Putting in 30W oil at the peak of summer time, that oil is not going to last very long in this heat and dust.
At the moment I wont name names here but I pretty much sure most know who I am talking about. One of our members work for a local oil company here and I remember asking him if all the specs mentioned on their cans are true or they just print them out on it with actually meeting those grades and specs for example API and SAE ratings. Unless you're buying oil which is cheaper than bottled water made in a shed somewhere in Saniyaistan from recycled old oil. I think you'd be alright with any decent brand, stick to the recommended grade and interval and you should be alright
AND as I always say, oil is cheap but and transmissions arn't. IMO no harm done to an early oil change with right oil. How much extra you gonna spend in a year if you do, worth the extra peace of mind IMO
And always before our valued internet warriors come crashing down on me, consider this, this is a still very debated subject, there are 1000s of pages on the interwebz on this, you can choose to be on whatever side you choose to be. This is just my own opinion and advise, as always free to accept it at your own risk and free to disregard it.
Thanks :D
From my cars manual
I seriously think onus is on the owner, as all petrol station here sells the most expensive (fully synthetic) to most cheapest (mineral oil) in all emirates. I remember when I had Cayenne turbo who needs topping up 1L every 1500 kms I used to buy fully synthetic oil from ENOC and never had any issues. Having said that, I do not get the oil change at any petrol station as I love one specific oil brand that I always stick to, it's kind of brand loyalty because whenever I put that in my car I can see the instant improvement from response, idle pinking, mileage and so on.
I think barry reaction is of the interval more than the temperature rating to be honest, as outside temperature is only 25% of actual temperature inside the sump, in excess of 250 degrees.
Second big thing is all owner MUST read and stick to car manufacturer specifications, as that's the best and safest way to keep your car happy. Once you know which type, then you can select the brand based on price vs experience vs convenience.
I agree with desertdude that changing oil little early is much better than waiting for exact kms, as oil is so cheap and readily available that one should never ignore or delay that.
In a country where even a can of coke that costs AED 1.50 is being ordered over the phone to deliver to the house, or someone blocks traffic just to stop by a grocery store to honk and get it delivered to his car when he could park his car about 2 minutes walk and get it himself, it is a tough ask for such lazy people to read and understand their car. They rather go to someone who treats them like arbab, charge them a dime and get his engine to give torubles after some time so that their garage is full and they can earn more from the damage done to these engines. In a population where we have over a million cars on road, an excellent forum like Carnity has less than 15,000 members out of which many are not active. Not everybody is as passionate about their cars to know more about it, all they want to do is have the biggest, baddest ride in town and being totally unaware of what is happening underneath the hood. A few active people here can talk all they want, but these are the people who are aware and care about their rides and have some knowledge, and dig out information from like minded people when needed. Others just don't care, but they are not on the forum to read and understand and base their actions on advise from the great people in this community. Keep sharing @Barry, @Gaurav, @taqirr, @desertdude. You guys are doing a great job sharing such important information, just hoping that more people would be involved. Some of us buy second hand cars and just imagine if we were to get our hands on a ride from one of the idiots who knows nothing about his car. Just recently I did not make a purchase f a Jeep Grand Cherokee 5.7 litre hemi because of the attitude of the person who was selling it. When i started asking him questions about the maintenance of his vehicle, he snapped at me and said if you don't want to buy the Jeep than thank you for wasting my time. Shocking.
@Barryis right- quick lube joints are a plague upon the face of the earth, and they should be eradicated. How to do this is perhaps a topic for another discussion though.
@desertdude is also right when he says that heat is one of the biggest factors that break down oil, but heat does not break down the base oil- heat breaks down the additives in the oil, and especially the detergents, which is mainly what causes the sludge that Barry found in the engine he shows in his post.
However, ambient heat is not the problem. The real problem is that the ultimate temperature the oil reaches, (as Gaurav correctly points out), moisture in the oil, poor quality additives, and mixing different brands of oil all combine to reduce the overall lubricity of  the oil in the engine. Let’s look at each factor-
1.)    Moisture collects in all engines when they cool down. Eventually, this moisture combines with the sulfur in the base oil, and when this mix is heated as the engine warms up, you end up with sulfuric acid when certain combustion products are added to the mix. There is nothing anyone can do about this- it is a simple chemical reaction that occurs in all engines that use mineral oil.
2.)    Some oil manufacturers use the cheapest additives they can find, but more importantly, they do not always balance the proportions of these additives to ensure efficient lubrication from one production batch to the next. For instance, friction modifiers need viscosity improvers to prevent the friction modifiers from settling out, so if they do not add enough viscosity improver of the correct type and grade, you may end up with all the friction modifiers in the bottom of the sump, instead of being evenly distributed throughout the oil matrix.
3.)    NO two oil companies use the same additive packages in their final product, even though their spec sheets “confirm” that the product meets or exceeds any number of specifications. Thus, it often happens that when you mix different brands of oil, you end up with a mix where one type of additive interferes with the function of the same type of additive in the oil already in the engine. This happens more with detergents and anti-foaming agents, and it can even happen that two different detergents can “cancel” each other out, which means that the oil mix in an engine may have no, or very little cleaning properties
Then there is the issue of oil standards. For instance, oil that conforms to the America SAE standard does not have to take into account the special needs that same engines may have. All American oil has to do is pass the crude standards of the Clean Air Act, and then just barely.
By comparison, European oil standards require that all oil grades bearing the ACEA (European Automobile Manufacturers' Association) seal must comply with standards that are specified by European car manufacturers, which is why sludge in European engines is unheard of in Europe. This has nothing do with European sensibilities; it has to do with proper quality control standards, which state (among other things) that all ACEA oils of any given grade must all contain additives of the same quality, and in the same amounts, regardless of who the ACEA-approved oil manufacturer is.
Overall, and because all things are NOT equal when it comes to engine oil, I agree with @Gaurav when he says that the onus is on the car owner to make sure he gets the oil that is best for his particular vehicle. However, I will be the first to admit that this is not an easy thing to do in a market where used oil can be collected, mechanically filtered, and then sold as “virgin oil”.
Thus, the only real advice I have is for people to stick to the oil grade and brand recommended by the manufacturers of their vehicles, and NEVER to mix oil brands, even if they are of the same grade. How often oil is changed is largely up to individuals, and if they can afford it, there is nothing wrong with replacing oil more frequently than the manufacturer of their vehicle specifies, but there is really no need to replace oil every 3000, or even 5000 km. This is just wasting money.
However, oil change intervals should NEVER exceed recommended times, but changing oil a few thousand KM earlier cannot do any harm, and especially on vehicles with 15 000 km (or longer) oil change intervals.
Bear in mind that the additive problem applies to synthetic oil as much as it does to mineral oil, since synthetic oil is nothing by an improved version of mineral oil that is distilled from various hydrocarbon-rich gases. Synthetic base oils also require additives to work, but because the molecules in synthetic oils are all the same size, this type of oil lasts longer because the load of lubricating the engine is shared equally among all the molecules, which is not the case with mineral oil.
Nonetheless, new generation synthetic oils do NOT mix well with ANY other oils, including most old- generation synthetic oils, so if you want to use synthetic oil in an engine that is not designed specifically for synthetic oil, make damn sure you get the right synthetic oil that will mix with what you have in your engine now, or, end up with the amount of sludge Barry found in the engine he shows.
Some really very good and valid point made by everyone above. I like what Gaurav said is owner education is must, and whole system anywhere in the world will take you for a ride if you are not aware of your choices. Imaging in UK people driving diesel car, go to petrol station and pour petrol from their own hands. We are discussing about engine oil specifics...lols.....!
I seriously think such uneducated / rich / careless / stupid / arrogant car owners deserve 1 million times more sludge than what barry found out.
Happy sludging you dumb morons.
Another food for thought, that why not car manufacturer write on top of oil cap that exact specification (one or two types) is compatible with their cars. Hiding this key info on 648th page in owner manual is cheeky from car manufacturers side too.
