slick72 Posted February 6, 2017 Report Share Posted February 6, 2017 Hi All, Good evening ! Can some one advise on a place for under body painting / may be rust proofing of my Nissan Xterra . Many thanks in advance ! Drive / Ride safe ! Slick72 P.S: May be the approx cost and time taken ..... ; ) Link to comment Share on other sites More sharing options...
derik Posted February 6, 2017 Report Share Posted February 6, 2017 To be honest, rust proofing is not really required if you are in Dubai or Sharjah. It's majorly required in northern emirates due to heavy coastal line and plus bad road network. You can try apex gulf they do the rust proofing and also you can check with Nissan dealer arabian automobiles, I am sure they also do that but off course double the outside price. Link to comment Share on other sites More sharing options...
desertdude Posted February 6, 2017 Report Share Posted February 6, 2017 Zeibart next to Galadari/Mazda showroom besides Dubai Airport Link to comment Share on other sites More sharing options...
slick72 Posted February 7, 2017 Author Report Share Posted February 7, 2017 (edited) Thanks Derik and Desert Dude ,... I didn't pose the question right need to have the under body stuff like the diff, control arms and other stuff to be painted have some some rust . Drive/Ride safe ! Slick72 Edited February 7, 2017 by slick72 Link to comment Share on other sites More sharing options...
derik Posted February 7, 2017 Report Share Posted February 7, 2017 This much you can do it yourself with normal black paint spray can. If you want good quality long lasting job buy some rust proofing can from ACE hardware and do it yourself by going under the car. Lift the car with jack for slightly easy access and that's it. You really can't go wrong in just spraying some paint in specific areas. Link to comment Share on other sites More sharing options...
slick72 Posted February 7, 2017 Author Report Share Posted February 7, 2017 Hi Derik thanks , the control arms and the diff also needs to be painted , would rather prefer to have the rust removed and then paint them ..... will be probably seek Location garage assistance to use their lift post ... Drive / Ride safe , Slick 72 Link to comment Share on other sites More sharing options...
Barry Posted February 7, 2017 Report Share Posted February 7, 2017 Hi Deepak. Give me a call after the weekend and I'll see about organizing the use of a lift for you. I might even make an appearance and help you 😉 With regards to painting underside components, a good scrub with a wire brush, wipe with thinners then hammerite brushed on is as good as anything. Rattle can paint looks good but it's not really a durable finish. If you want to be really flashy, you can disassemble everything and get it powder coated. This is what I used to do when I worked in the restoration business. As @derik said above though, rust isn't really an issue here in UAE. It's just surface rust, it rarely eats through things. Back home in Ireland it's a real pain in the ass. Every winter they treat the roads with salt to get rid of the ice. Salt is a major catalyst for rust. Come spring time, it's 2 months flat out welding older cars patching sills and wheel arches. As for rustproofing products, all I have ever used is Waxoyl. Bilt Hamber and Dinitrol also make alternative products but I have no experience of them. Pump it inside the chassis, sills and everywhere else. This is why vehicles have plastic rubber bungs in random places underneath, excluding the floor drains. Waxoyl is good but I don't think it would cope too well with an off-road vehicle here as the sand would scrub it off. What they used to do in the olden days is use waste oil. Brush it on thick all over the bottom of the car and the oil repels the water. It's not particularly durable, it needs to be done 2-3 times a year but it works. I can remember my grandad doing it on his Austin 1800 when I was a kid. 2 Link to comment Share on other sites More sharing options...
