displays blanked out
hamid
Guys - this is very creepy, i have never had this issue ever ... my 07 CTS ran like a gem since the day I bought it ... The battery and everything is fresh and working fine ... This evening on my way back from work i noticed that my display and everything else electronic just went blank ... just stopped working.
I checked my battery and did the re-connection and all but still there is no luck. Do I have to take it in?
Thanks
  • 1 month later...
Assuming if car starts and run fine and only the display lights is not on, then more than likely car is OK and just some fuse or loose connection is misbehaving. In this scenario, you should first check for the fuse box in the trunk on driver side by removing the back panel of the trunk to reach the electronics boxes located on back of it. In the fuse box there is a diagram and see if any fuse is blown out. The trunk compartment fuse block is accessed by pulling back the trunk liner at the hinge on the driver's side. The fuses to look for are a 20 Amp CLUSTER FUSE, a 10 Amp RLY IGN1 FUSE, and a 10 Amp IGN0-BODY FUSE.
Once fuse is replaced, try disconnecting the battery and reconnect after cleaning the both terminal of corrosion and make sure earthing is properly connected. Many times blown fuse is caused due to voltage fluctuation from dirty battery terminal or loose ground (earth wire).
