Amar
Kia Optima speedometer change from miles to kms
14 posts in this topic
Hi, All.
Good day.
I have a Kia Optima 2012 and it is American Spec. The speedometer shows the unit of MILES for the car driven and I want to change to KM on the speedometer, can anyone please help me as to where & who can do this.?
Appreciate your kind reply/help.
Amar
If I am not wrong I think you got to change the whole instrument panel with GCC specs or similar car that shows in Kms. More experts can comment here: @Barry @shadow79
shadow79 and Amar like this
That also if the sockets match or else you have to remove the instrument cluster and put in a larger kms sticker so that it will point to right kmhs....
Posted (edited)
You can buy sticker kits on eBay. You can even change the color of the dash clocks if you want. I've had to do it the other way round before, kph to mph with imports coming from Japan to U.K.
Bear in mind that if you do this, your odometer will be wrong as it is reading in miles instead of kilometers.
Edited by Barry
shadow79 likes this
Thanks to all for the reply.
Isn't there any programming for the cluster which can change it. What if I buy an instrument cluster which reads KM will it help and also do I have to reprogramme it?.
Hi Guys, One more thing, as suggested by Barry above, my speedometer had both KM as well as Miles on the dial which is not a problem for me. I am talking about the reading which shows distance traveled.
PLEASE SEE ATTACHED PIC
Have you tried going through the onboard computer to see if there's a setting to change it?
Posted (edited)
Hello, Barry. Yes, I tried with all the settings.
Edited by Amar
message
I just tried using the menu buttons on the steering wheel, other than that I haven't tried anything else.Is there any program or software that can change the Miles to KM.
You have to swap it with a GCC 1
    • Engine Oil leaking from bottom.
    • Got my license
      Got my license
    • Newbie/Fewbie drive with Suhoor - 22 June
    • Battery charger
      Battery charger
    • Richard Hammond involved in another serious crash
    • Area 53 to Iftar Bowl - Night Drive - 15 June 2017
    • New job
      New job
    • Prado Cabin Noise
      Prado Cabin Noise
    • Coolent Leak
      Coolent Leak
    • Adjustable electronic window tints
    • Great Grand Iftar Drive - 9 June 2017
    • Ford pothole jumping suspension
    • Suhoor night drive - 1 June 2017
    • Viking rope and soft shackles
