Noise cant be identified
rockyland
Hi there rocky I quite don't really understand which kind of noise you are talking about .. it can be anything ... does the noise seem to change when the engine changes its temperate? (Since you mentioned that it is louder when you reverse) ... can also be the transmission. Have you tried to identify the source of the noise?
Well two things come to my mind instantly - it could be the belt or the power steering since the latter can potentially make noise. Try letting your motor run and place your ear next to the power steering pump to see if the noise has any connection there.
