balajitr Posted August 10, 2017 Report Share Posted August 10, 2017 My Edge Sport 2016 came with 265/40R21 tyres. While it does look nice, I would prefer not to feel every imperfection on the road. I don't make sharp turns at high speeds and so I don't need the better handling capability of the huge wheels. I chose the sport model over the titanium one for the EB engine and its straight line pickup. I had a Murano earlier and its 235/65R18 tyres were so much more comfortable. This URL tells me that the below tyres (and appropriate rims) are also compatible with this model. 235/60R18 245/60R18 245/55R19 245/50R20 The owner's manual confirms that 235/60R18 is indeed the 'winter' tyre size. My 2 questions: 1. Has anyone downsized their tyres and found that the ride comfort is better? 2. Recommendations for good wheel and tyre shops as I can't find any this combination on any of the online sites? Thanks to all in advance. Link to comment Share on other sites More sharing options...
desertdude Posted August 12, 2017 Report Share Posted August 12, 2017 You are right. 21s are pretty bone jarring on anything less than a very smooth surface. You can go down to 245/60 18 without any issues because your tyre diameter will largely remain unaffected and your ride will be a lot more smoother too. Until that time check if you are not over inflated too. And also this heat will increase your tyre pressure by quite a bit, making the tyre even stiffer. 1 Link to comment Share on other sites More sharing options...
balajitr Posted August 12, 2017 Author Report Share Posted August 12, 2017 1 hour ago, desertdude said: Until that time check if you are not over inflated too. And also this heat will increase your tyre pressure by quite a bit, making the tyre even stiffer. Yes, I wondered about that; the difference is 3PSI after just 30 minutes of driving. I often adjust the pressure so that the cold tyre pressure is 2 PSI below the recommended one. Link to comment Share on other sites More sharing options...
