Hi all.
Byron
Hi guys, Alf over at U-Fix-it garage pointed me towards this place. Looking around a bit and it seems pretty nice.
I have an older 2006 CTS-V1 that has been modified a bit. Mostly suspension and rear end, long tubes and high flow cats plus tuning.
Total list of things changed is KW Var 3 coils, 5 lug conversion, 2010 Camaro SS rotors, poly bushings, poly cradle mounts, new drive shaft, LS7 clutch setup, wilwood master cylinder, long tube headders into high flow cats and a H pipe, new head lights, short throw shifter, I also run a Ford 8.8 irs rear end with DSS axles, tuning, cold air intake tube I built and various other little changes.
I do a very good portion of my own manitenance whenever possible. I also own a tech 2 if anyone needs it.
-Byron
Click the link below to a high quality exhaust video with DB meter reading.
Edited by Byron
Hi Byron, welcome to the right place and seems like you have done quite a lot of things already to your CTS. Really impressive.
I will be really excited to see and learn from your next project, as I always wanted to do some DIY stuff but always fall short of time and real guts to work on my own car.
