fuel pressure regulator
Fuel pressure regulator helps in the maintenance of the operating pressure to be proper. It helps in compensating the changes in engine load. There can be a problem in the fuel pump. Its broken or damaged and thus fuel pressure regulator is also failing. You can go to an expert and tell him to examine the regulator properly and replace it if required.
