stearing wheel problem
good morning,
i have a Chevrolet impala 1994 model, it is a beautiful vehicle and have never given me any problems till date but recently i have noticed that my staring wheel is a bit hard when i start my car in the morning and stiffness is there for a couple of min. what cud be the issue.
thanks for the help in advance
Check PSF (Power Steering Fluid) also used as ATF in many cases.
Top up this and see for next day if it stays same.
Ways to top up this fluid is little tricky. Open canister and top up if needed. Then start the car and turn full wheel left and top up again, then turn full wheel right and top up again. After that turn steering left and right 5 - 10 times and see if more fluid is needed. If not close the canister and check next day morning, hopefully it will be fine.
