Hello,
Any one please advise how to stop speeding alarm in GRAND VITARA which start when I hit 120km speed  and never stops until I slow down.
Please someone save from the daily irritation
Open the dash clocks, find the beeper and either unsolder it or stab it with a screwdriver. Can’t be deactivated as far as I know.
I agree it can't be disabled as its a norm for GCC spec and the only person who can disable it is the agency and they will never agree to do it to contradict with GCC specs. So Barry route is much better, faster, easier and permanent.
I wouldn't advise that, since a lot of cars also use the same for other warnings for example in my car although I dont have the 120 buzzer the annoying gong, goes off if any warning light comes on or it detects something wrong too
And why do you want to drive over 120 anyways?
Well it's not always the case as speed limit has a chime and warning have beep / beeps, so it depends what Suzuki opted for, but still with little DIY experiments and research, you can isolate this issue.
Generally most speed limits are 100kph but you can push it to 120. The road to Abu Dhabi has a 160 limit so I can understand.
Upgrade your music system. It works fine for me. And yes this is for GCC specs only. I had a USA spec Mitsubishi Eclipse never beeped once even on 220 KPH.
This is a nice mod
  • Like 3
  • Similar Content
    • By Recall
      ANNOUNCEMENT
      Safety Recall Campaign for Suzuki — Kizashi & SX4 2.0 in UAE
      In co-ordination with Ministry of Economy —Department of Consumer Protection, and in line with the objectives of the Ministry of Economy to conduct an ongoing review of all products in the UAE and provide the consumer with the required protection.
      Al Rostamani Trading Co sole authorized distributor of Suzuki in UAE announces Safety Recall Campaign for Suzuki KIZAS1-11 2010-2012 YM and Suzuki SX4 2.0 2010-2012 YM.
      Due to an improper structure for the shift lock mechanism of the shift select lever, the mechanism might be broken when the lever is operated with excessive force to move it from parking range to other range without depressing the brake pedal. Consequently the lever could be pulled from parking range to other range without depressing the brake pedal.
      Decision has been taken jointly with Suzuki Motor Corporation and the Ministry of Economy — Department of Consumer Protection, to launch a Safety Recall Campaign to carry out the inspection of those vehicles affected in the UAE and have it replaced with the modified Part.
      Al Rostamani Trading Co will contact the affected vehicle owners individually to inform and give an appointment for the carrying out the replacement of the part.
      The replacement of the Part will be made free of charge and every effort will be made to minimize the downtime for the repairs.
      For more information, call Al Rostamani Trading Co. Tel No 04 2955907, Ext 2128. Work Timing 8:00am — 5:30 pm (Sat — Wed) and 8:00am — 01:30pm (Thurs)
      Ministry of Economy Hotline No: 600 522 225
    • By Recall
      ANNOUNCEMENT
      Recall Campaign for Suzuki — Celerio in UAE
      Al Rostamani Trading Co sole authorized distributor of Suzuki in UAE announces Recall Campaign for Suzuki Celerio (2009-2010 YM)
      Due to the mis-arranged wiring harness where shift solenoid circuit and stop lamp circuit were wrongly interchanged, higher electric current than designed was flowing through shift solenoid for the automatic transmission shift selector lever lock circuit. Higher electric current could cause the shift solenoid circuit contact in the stop lamp switch to be burnt/melted that might result in stop lamp switch failure. In such a case, the automatic transmission selector lever coincidently may not be pulled out of 'P' range.
      Decision has been taken jointly with Suzuki Motor Corporation and the Ministry of Economy — Department of Consumer Protection, to launch a Recall Campaign to carry out the inspection of those vehicles affected in the UAE and have it replaced with the modified Part.
      For more information, call Al Rostamani Trading Co. Tel No 04 2955907, Ext 2128. Work Timing 8:00am — 5:30 pm (Sat — Wed) and 8:00am — 01:30pm (Thurs )
    • By Recall
      ANNOUNCEMENT
      Safety Recall Campaign for Suzuki —Grand Vitara 2.7/1.6 & Jimny 1.3 in UAE
      In co-ordination with Ministry of Economy — Department of Consumer Protection, and in line with the objectives of the Ministry of Economy to conduct an ongoing review of all products in the UAE and provide the consumer with the required protection.
      Al Rostamani Trading Co sole authorized distributor of Suzuki in UAE announces Recall Campaign for Suzuki Grand vitara 1.6 (2005-2006 YM), Suzuki Grand vitara 2.7 (2005-2006 YM) & Suzuki Jimny 1.3 (2005-2006 YM)
      Due to the improper material of the plastic outer race of tensioner pulley for adjusting tension of the belt which drives power steering pump, the outer race may be broken causing abnormal noise. In worst case, the belt could be departed from the tensioner pulley resulting in steering effort getting increased.
      Decision has been taken jointly with Suzuki Motor Corporation and the Ministry of Economy — Department of Consumer Protection, to launch a safety Recall Campaign to carry out the inspection of those vehicles affected in the UAE and have it replaced with the modified Part.
    • By Recall
      ANNOUNCEMENT
      Safety Recall Campaign for Suzuki — Grand Vitara 2.4 in UAE
      Al Rostamani Trading Co sole authorized distributor of Suzuki in UAE announces Safety Recall Campaign for Suzuki Grand Vitara 2008 to 2011 YM.
      As internal spring of the belt tension adjuster was manufactured improperly, the spring may be broken and the tension of the belt will not be adjusted. In which case the belt will be slipped and the generator and water pump pulleys will not work.. In the worst case, the belt may come out from power steering pump pulley and driver will need increased effort to steer the vehicle.
