Airbag repair
Anyone got a reliable supplier who can refurb a suspension airbag?
I really doubt and I wouldn't advise to refurb the suspension airbag as it's more of a consumable item as rubber tends to crack and fail with time and heat. Even if you try something from scrap at half the cost it will fail in a quarter of life, so always advice to go with new.
If the owner is tired of changing again and again, then you can look into ARNOTT website if they manufacture for your vehicle as they usually have far better quality than any OEM and backed with their limited lifetime warranty.
I have no qualms about using reconditioned airbags and I’ve used them many times with no ill consequences. After all, it’s just a series of moving parts. You wouldn’t thing twice about changing a set of brushes or a solenoid on a starter motor.
Buying a new unit would be ideal for me to swap out but it’s an older supercar so it’s extremely cost prohibitive, hence looking for someone who can repair it.
There are quite a few places in shj doing refurbs or more correctly replace air suspension airbags. Just need to get them the struts, last time I checked it was 500dhs per corner for a RR with a 15 day warranty.
What car is it anyways, might be able to give better info
auto jabain and auto chockup are some shops from where i got refurbished shocks for a merc and rr i guess they also repair and give warranty on their work
they both are at cola road
Got any contact numbers for them?
guess after eid i will be going there to search for some parts in that area will get numbers for you...
Sorted. Got a repair kit online and did it myself. Surprisingly easy to do too. 15 minutes rebuilds the units. The biggest job is taking the strut out of the car.
Link please!
eBay seller autoparts-mall
