Blower for filter and car mat cleaning
Atif
I need advice on buying a blower that can be used to clean car air filters as well as for car mat cleaning. I don’t mind buying an invertor too if 12 v blowers will be low wattage, however in this case need to know which invertor too (my Prado has a built in one but max 100 W).
Suitable budget around 350 aed
Just an idea at @Atif, why don't you use an air compressor fro Dragon Mart for under AED 200. It will help you to blow all the dust away and will be useful in case you loose tyre pressure for any reason.
I have tried the compressor which we use to fill up our tyres for cleaning the airfilter and found it to be very ineffective.
you will need a compressor with more pressure for effective cleaning, something that will generate upto 5 bar of pressure
  • Thanks (+1) 2
