hossein Posted January 3, 2019 Report Share Posted January 3, 2019 (edited) 20 minutes ago, Frederic Nuyttens said: @hossein let me know if the trick with pulling the ABS fuse works, i might need it in the future on my wife's car If positive, then it can be easily solved by doing some small wiring like in attached pic. The fuse in the wiring diagram that goes into the car's fusebox has to be a busted one of course, otherwise it won't work. You can use an old busted fuse, break it open and solder 2 wires to the blades. Dear @Frederic NuyttensYes should be work but as my research maybe around 80% will kill traction control, I will test it this Friday to traction control will engage or not (by ECU ) but when you pull the fuse the ABS, traction control, Handbrake and ABS light will switch on. Edited January 3, 2019 by hossein Link to comment Share on other sites More sharing options...
hossein Posted January 8, 2019 Report Share Posted January 8, 2019 On 1/3/2019 at 11:02 AM, Frederic Nuyttens said: @hossein let me know if the trick with pulling the ABS fuse works, i might need it in the future on my wife's car If positive, then it can be easily solved by doing some small wiring like in attached pic. The fuse in the wiring diagram that goes into the car's fusebox has to be a busted one of course, otherwise it won't work. You can use an old busted fuse, break it open and solder 2 wires to the blades. @Frederic Nuyttens its 100% worked, please check if this way 👆 is possible because removing and putting back the fuse causes damage the fuse box and terminals Thanks 1 Link to comment Share on other sites More sharing options...
Frederic Posted January 8, 2019 Report Share Posted January 8, 2019 6 minutes ago, hossein said: @Frederic Nuyttens its 100% worked, please check if this way 👆 is possible because removing and putting back the fuse causes damage the fuse box and terminals Thanks Hi Hossein, Yes above option should definitely work. Any local car workshop can easily do this in about 40 minutes.You can maybe show them the diagram, or do it yourself if you're a bit handy with wiring and soldering. 1 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
hossein Posted January 8, 2019 Report Share Posted January 8, 2019 20 minutes ago, Frederic Nuyttens said: Hi Hossein, Yes above option should definitely work. Any local car workshop can easily do this in about 40 minutes.You can maybe show them the diagram, or do it yourself if you're a bit handy with wiring and soldering. Dear Fredric, Thanks, I will check this option and kill switch, one of those necessary to be installed 1 Link to comment Share on other sites More sharing options...
