is it the weather or my car is having overheating problem
If its import then please change the thermostat immediately as it might be opening and closing at higher temperature, whereas in GCC cars it works quite early.
If GCC specs car then you should check if all fan is working fine esp AC fan, radiator isnt clogged or leaking, car is serviced well etc.
Never overlook overheating in time or else it will cost you LOT MORE later.
