i am confused over my car overheating
my ride started to overheat and the AC started to cut of as of my research i have found out that there could be a number of reasons for this like the temp. gauge fuse relay radiator leak fan etc which i have got everything checked and nothing seems to be wrong
then where an i not looking to fine the cause.
please assist me in this problem.
thanks
Change the thermostat and if still same you ca doubt water pump. After changing thermostat and before doubting water pump make sure things u mention in ur list is working fine.
Radiator isnt leaking
Main engine fan is woking
AC fab is working and then doubt
water pump in end, as its expensive to change.
