leak in the rear main engine
Leak from engine is engine oil. If its very minor, its pretty acceptable and if its major that after every parking you see spot on floor get it fixed. For fixing you ned that rear seal and mechanic who can lift the car and fix the seal from behind the engine. Its pretty straight forward but technical job.
