Parking position is jammed
When you turn ignition on it releases a cable that is attached to the shifter also the shifter has a solenoid attached to it that is released when you step on the brake. Most time when you have this problem of button stuck and cant shift out of park the solenoid usually sticking and wouldn't release. Disconnect the battery then go turn the ignition to on position then try to shift into neutral if it does need to replace brake switch or wiring connection . You can leave in nuetral turn ignition off might not go to lock but hook battery up should be able to shift until you put back in park until you get switch replaced.
  • 2 weeks later...
