agc0629
HOLD Light Continously Blinking
15 posts in this topic
Hi Optra Chevy Team,
I have a 2007 Chevy Optra 2007 1.8 LT. When i am shifting to REVERSE gear sometimes HOLD will come in the dashboard & continuously blinking. Once this happened & shift gear to DRIVE then the gearbox will Jerk. Then it runs like it's stuck into 3rd or 4th gear with difficult in acceleration. Do you have idea guys why this is happening & what is to be done? There's no more warranty. Hope there's solution if i bring to Service centre, hope this would not cost a lot.
Thanks Guys and i am waiting for your expertise reply.A
e.alasker likes this
Just so as you know, we arent from chevy team. We are owners like u are.
What i can guess is this must be happening when u slow down car and before coming to complete halt u engage the reverse gear. Its an indication to tell you to hold that gear is still engaged in fwd motion and you should bring car to zero speed and then shift to reverse. hope it helps.
@evon thanks for your reply. But even my car is in Parking for a day then doing the reverse, it is also happening. Do you think this is a sort of a P&N Switch issue?
Well i dont think its issue of gear lever, it may be a gear solenoid which might be acting funny. Better get it checked and diagnose with someone having chevy computer diagnostic tool and see which fault it points to? These computer check cost about 200dhs but will saves lot of time and money in guess work.
Brought the car to SC in ras al khor. Diagnosed with P0706 code. TP Switch changed and now it's working fine. Thanks
where in Ras Al Khor?
Al Ghandi Service Center. Just check their website so u can see the location map
same same saaamme problem and they changed the switch and now is working well. thanks
    • Happy birthday Ayrton Senna
    • Door edge protector
      Door edge protector
    • Hydro dipping
      Hydro dipping
    • Fibreglass work
      Fibreglass work
    • JDM Goodness
      JDM Goodness
    • Newbie Family Adventure Drive with BBQ - 24 March 2017
    • Maserati Levante
      Maserati Levante
    • Thrilling dune bashing from Murqquab to Lisalli - 17 March 2017
    • Malfunction Indicator P0335
    • Drive to Sweihan Sand Mountains - 10 March 2017
    • The Patrol from The Grand Tour
    • Wadi Shawka Adventurous Drive - 3 March 2017
    • Side door logo strip
    • Initial D
      Initial D
    • Jeep JK Lift Kit - Fox performance 2.0 IFP with Rubicon Express Lift Kit
    • Scenic drive to natural lake - onroad + off-road - 24 Feb 2017
