Temp gauge needle going 3/4
i have epica 2007 i notice the temp gauge going up to 3/4 (7th line)when i stop (traffic sign) and going down (Middle 5th line) when its running, is that normal specially the climate is hot?!
I remove the engine plastic cover already and the normal temp. is below the middle but still going up to 3/4 when stop..
any advice there...
thanks... :D
Engine plastic removing is a fraction of reducing engine heat to dissipate. For overheating get the following things check below in same order as per their priorities:
Get the coolant level check
Get the AC fan check
Get the engine fan check
Get the radiator check for blockage due to corrosion
Get the thermostat check or better change if you haven't changed it in last 3 years.
