ice.alba Posted August 28, 2012 Report Share Posted August 28, 2012 i have epica 2007 i notice the temp gauge going up to 3/4 (7th line)when i stop (traffic sign) and going down (Middle 5th line) when its running, is that normal specially the climate is hot?! I remove the engine plastic cover already and the normal temp. is below the middle but still going up to 3/4 when stop.. any advice there... thanks... Link to comment Share on other sites More sharing options...
Shabir Posted August 28, 2012 Report Share Posted August 28, 2012 Engine plastic removing is a fraction of reducing engine heat to dissipate. For overheating get the following things check below in same order as per their priorities: Get the coolant level check Get the AC fan check Get the engine fan check Get the radiator check for blockage due to corrosion Get the thermostat check or better change if you haven't changed it in last 3 years. Link to comment Share on other sites More sharing options...
ice.alba Posted August 29, 2012 Author Report Share Posted August 29, 2012 i replace already all the radiator, hose, and thermostat, even the the fan is working properly, and also the coolant level is ok, do you think that is cylinder head gasket or what?! thanks... Link to comment Share on other sites More sharing options...
