confused cruise control
So my good old silverado is acting up a bit now and I am thinking of moving on to another car ... till the time I get to that point I wanted to know what would a person do if the cruise control just pauses without any reason. It almost seems as if it is not working sometimes and at times its never been so perfect.
my first instinct is the gear on the steering wheel - any other ideas would be appreciated.
Ciao
In my scenario the reason why my cruise control got stalled at times was the brake switch. I had to go under the dash to find out the problem ... if you know what I am talking about then you might want to check the switches under the dash which are connected to the brake pedal. Do this before you take it in so that you know that this is the problem.
  • 3 weeks later...
