Headlights Dim!!!
When such a thing happens, the problem is issued in the charging system, it may be because of bad alternator. You can use the voltmeter to check the voltage is the charging system. if the reading is lesser than 13 volts, then surely the charging system has failed and need to repair/replace it.
