fuse for the indicator
ghil
Under the steering small fuse box is there, check in there as per the diagram on cover.
It is the large black panel just behind the emergency brake/ dead pedal, there is a plastic door covering the fuses. You need to squeeze in on the plastic clips that are on the top and bottom of the plastic door then it can be removed by pulling it outward toward the passenger side of the car. It is not very convenient to access especially since there is a wiring loom that partially blocks access to the fuse door. Hope that helps.
  • 1 year later...
  • 1 month later...
  • 4 weeks later...
