break changing
Disk and Drums are same thing bro.
I guess you meant while changing brake pads is it imp. to change the Disc as well???
Answer is no, if brake disc/drum have enough thickness above 5mm then you dont need to. However getting polish (lathe/turning) is always advisable so that your new brake pad mate nicely with drum and have even wear.
