The reverse Audi A3 sensor are not working.
tucson
  • 3 years later...
It might need to get cleaned, so you want to check that out. If the sensor is clean and still not working, check if the error code is showing any problem; you can follow the step indicated in the car's manual to fix the problem, but If you're not familiar with this, I suggest taking it to a mechanic.
