Roden737
MFT RDS not working
Anyone else having problems activating the rds on the mft?
Couldn't use it when I got my edge (2012 SEL) also after installing the update last week there was no change..
Thanks!
Nope, didn't try that yet..
Figured that if it doesn't work on virgin it's not gonna work on a different station but I will give it a go..
Answer from the dealer was that it's not available in the UAE..
You should tune to Raido station and then you should see the station info on lower left hand corner.
When in Radio screen go to options and select RDS text display set to ON. For this to work you should make sure that your Direct Tune is not highlighted.
If still cant fix this, try master reset: Menu - settings - system - master reset.
Hope that helps, mate.
Hi all,
I have the same issue.
My 2012 Edge went for service last week and software got upgraded.
Before the service I asked if RDS issue would be fixed and they replied "Its a known issue, RDS in MFT doesn't work in the Middle East".
@salah, you gave very specific instructions, is yours working?
Cheers!
