when are brakes changed?
  • 3 months later...
sent to the workshop and they should be able to advise whether you need to change. the brakepads are designed to wear out rather than the disc. but the disc will also eventually wear out. if the brakes feel soft, there mayb some air pockets in the hydraulic line (brake oil). jus ask the mechanic to bleed out the air and if required, top up your brake oil.
