why fuel gauge shows empty when its not?
dadenja
  • 11 months later...
  • 1 month later...
Its an issue with fuel sending sensor and not with fuel pump. If fuel pump is faulty you will experience hesitation in driving and especially in full throttle and in that scenario fuel gauge would show perfect. In your case its more than likely the the fuel sensor (which is cheaper to fix) or the fuel gauge (which is expensive to fix). Good luck.
