where is the fuel pump located?
  • 1 month later...
  • 1 month later...
you have to remove the rear seat and you'll find a metal black cover with 3 screws you have to remove it then you'll unlock the big plastic threaded cover around it then you can left up the pump assembly with fuel live sensor if you are going to replace it completely it would be around 1 1/2 hour if you are going to replace the pump only it would be about 2 hours but please be careful about the new pump pressure since it's aftermarket and hoses since it would be hard (it's old and socked in fuel for years) and connections since the fuel return line in the same assembly please be sure not to switch ignition key at any positions to avoid sparks don't smoke try to do it in daylight to avoid any type of heat near by.
you may find the after market pump at Damas spear part at Sharjah industrial area - BMW road be sure to have VIN number with you.
Good luck.
  • 2 weeks later...
  • 3 weeks later...
