Addional fan
Am getting an addional fan fix due to over heating of my TJ 98, went to a garage in SHJ who is selling me a dual fan for 350/- & fixing charges would be 100/- he says he will disconnect the orignal radiator fan & fix 1 inreplace & the other in between the radator & grill... please advice :?:
Don't replace the radiator fan to electric fan as it will chew lot of electric and make too much noise. If doubt on fan get new clutch fan instead.
Also as a aux cooling you can change the AC electrical fan to Kenlowe or something more hi power, no problem.
If want more cooling change the radiator to bigger lines and you will sort out cooling issue forever.
