JeepDxb
Is it a good idea to get a second hand Wrangler?
Is getting a second hand wrangler in this part of the world a good idea as i have seen most cars in the desert are wrangler so if i buy a second hand will it be damaged?
It is really iffy and im sure you can find a great second hand one. The do last a really long time, My 01 TJ has about 400,000 Km on it, and runs great. If you are looking for a used one i would suggest finding one that has been taken care of by a Jeep enthuist. This may make it a bit more expensive, but more often then not you can find a wrangler that has been well maintained with a few upgrades, such as lift kits, tyres, and lighting. My suggestion is dont rush into it. If you want to save a few bucks, check around on the internet daily for a few weeks, or months, till you find the one that fits your needs! Best of Luck
Jeep recommends 89 Octane for their V6, assuming that this is what you are running. Changing the fuel type to a higher grade, really wont benifit at all. You are pretty much just paying more to get the same results
Especially Jeep wrangler tells a lot of used by which nationality. If it's only road used and completely stock (which I highly doubt) then any nationality is fine.
If it's completely souped up then britishers and european are better nationality to buy as compare to arabs and middle eastern countries owners. No thread war intended here.
