Oil Sludge
Is oil sludge a common problem in Audi A4? I have heard many people complaining that because of the irregular oil change in the engine, Audi A4 reacts worst in this case compared to other cars as it results into oil sludge and you have o pay big money to fix it. Not really sure if its true. Can anyone share if they faced such a problem?
  • 2 months later...
Oil sludge is a common issue actually. The only thing manually you can do is clean the oil pan and remove the sludge as much as possible. Don’t try to clean the engine flush, it might get clogged. Best thing is to take it to the dealer, if your car is still under warranty, otherwise perform it manually but under the supervision of an expert.
  • 7 months later...
