AshleyA Posted March 24, 2013 Report Share Posted March 24, 2013 Hi, I have a 2008 Jeep Commander 5.7. 3 warning lights are appearing on my dashboard, ESP/BAS, ABS and traction control. My cruise control does not work and the error message reads service 4wd system. I took the car to Western Motors and they said it might be the speed sensore but couldn't be sure even as that was the obly fault code coming up. The car drives fine but today my check engine light also came on. Any help or advise PLEASE??? Link to comment Share on other sites More sharing options...
JeepDxb Posted March 27, 2013 Report Share Posted March 27, 2013 As a first rule, check all loose wires especially under driver seat and check all fuses for making sure that ABS modulator is alive. If that is alive and kicking then everything else is easier and cheaper to fix. Get the Jeep specific computer diagnostic as that will read all error and point in right direction. Link to comment Share on other sites More sharing options...
AshleyA Posted March 28, 2013 Author Report Share Posted March 28, 2013 Many thanks, I replace the front right speed sensor. All is in order again. Link to comment Share on other sites More sharing options...
khandelwal Posted March 28, 2013 Report Share Posted March 28, 2013 Seems more of an electrical glitch. Get computer check which will be for 100 aed only. Link to comment Share on other sites More sharing options...
JeepDxb Posted March 29, 2013 Report Share Posted March 29, 2013 You can also check crank shaft position sensor. If that is failing or gone crazy it throw all sort of warning lights and problems. Link to comment Share on other sites More sharing options...
JeepDxb Posted April 3, 2013 Report Share Posted April 3, 2013 is this sorted? Link to comment Share on other sites More sharing options...
AshleyA Posted April 3, 2013 Author Report Share Posted April 3, 2013 Yes, thanks. I replaced the right speed sensor and all is back to normal. Link to comment Share on other sites More sharing options...
JeepDxb Posted May 15, 2013 Report Share Posted May 15, 2013 i am looking for a jeep professional where did you get the sensors changed from. Link to comment Share on other sites More sharing options...
AshleyA Posted May 16, 2013 Author Report Share Posted May 16, 2013 HI ROY WESTERN MOTORS, ABU DHABI Link to comment Share on other sites More sharing options...
JeepDxb Posted May 29, 2013 Report Share Posted May 29, 2013 thanks man they were professionals. Link to comment Share on other sites More sharing options...
