help
i still have the same old problem
after i drive for 30 minutes, the car lose power and start jerking when i stop in traffic light, and the engine signal appear
i replaced all ignition coil, but the problem still
my friend want my to replace injectors, i am afraid it will not solve it
so, please can suggest a good work shop to check my car
You actually need a computer diagnostic to read which fault code is recorded when car jerks and show check engine light. Guesswork is not the best option always.
If its injector issue then it will also blip on full throttle and sometimes on constant drive. It may be a fuel pump issue, but you better get it check first before blowing further money. You can take your Jeep to 4x4 motors or Robbies in al quoz area, they do the computer testing, i think for 300 dhs.
