reason for missing
Check the spark plug, ignition coil and plug wire from outside first if its having some problem then fix it. (external issues)
If they all are fine then get the engine compression test done and see which cylinder is having low pressure and that cylinder is having stuck valves, injector or lifter/rocker there. (Internal issues)
