jake Posted August 5, 2013 Report Share Posted August 5, 2013 hello ... i am buying my first azera - its second hand with approx. 40,000 miles on it. When i test drove the vehicle i noticed that one or two error codes came up. Since this is my first hyundai i have no idea what they meant. Although the car worked perfectly fine and i have test driven it more than once to know that its in the best of conditions - should i be concerned about the error codes? Link to comment Share on other sites More sharing options...
gill Posted August 5, 2013 Report Share Posted August 5, 2013 Hi jake, Error codes are used to determine the problems with the car - its when the car signals you that there is something wrong so obviously you should be concerned about them before buying the car. Test driving the vehicle a couple of times does not help in determining anything so watch out - did you have a talk about the error codes with the seller? Link to comment Share on other sites More sharing options...
mahmood Posted August 7, 2013 Report Share Posted August 7, 2013 if you could have remembered which codes come up you could have determined the problem by yourself. If you can get a chance to go see the seller and test drive it one more time ... you can note down the error codes and see what the problems are. anyways ...here is a complete compilation of the error codes for you http://www.permoveo.ltd.uk/tabid/123/Diagnostics/Hyundai/Default.aspx Link to comment Share on other sites More sharing options...
dass Posted September 14, 2013 Report Share Posted September 14, 2013 This error code look up palce is awesome man. Thanks a lot for sharing such good and useful information. Link to comment Share on other sites More sharing options...
