rattling noise in the engine
Check for any light on dash like oil pressure light is lit or not????
This noise is very risky as may be your engine rocker port and valve lifter running dry due to less oil pressure. Just change the oil pressure sensor to be safe side and see if it throw some low oil pressure light......!
It is catastrophic if leave unattended, don't drive too high rpm until fix, it may seize your engine if its running dry.
