AC is smelling
  • 4 months later...
  • 6 months later...
Try this method if it will work. Spray Lysol directly into the vents then switch the air conditioner to run the air from the outside. Drive for about 2 miles then switch back to "recirculate air". You might also want to change the filters as it could also be the one that is causing the odor.
  • 9 months later...
  • 4 weeks later...
