how to change spark plugs?
tarmun
  • 1 month later...
First remove the engine cover. Then remove the sparkplugs electroinc igniter on top of spark plugs. Igniter is fixed with 10mm bolt and then pull out the spark plug wires and the spark plugs are inside the hole... then remove the spark plug with normal spark plug socket. This setup is also known as coil on plug setup.
  • 1 month later...
